pete-theobald Wrote:
> I haven't added acme leadscrews but I have
> upgraded to t2.5 with aluminium pulleys and had a
> look at what I would need to use acme leadscrews.
> For the t2.5 belts I put 16 tooth pulleys on all
> motors and 40 tooth on the ends of the leadscrews.
> To fix them in place I tapped the pulleys to m8
> and they are very well aligned to the centre of
> the shafts. I decided to tap the pulleys as an m8
> thread isn't exactly 8mm diameter as the threads
> rounded off at the end. Acme threads don't have
> this as far as I know so you could treat it as a
> straight shaft as far as mounting goes, especially
> as the thread is quite fine. I still use the
> grubscrews to secure the leadscrews but you also
> get some grip by tightening the bolt on the other
> side of the lower bearing.
> The reason I didn't upgrade to acme screws is that
> acme threaded nuts are quite expensive and the nut
> above the lower bearing takes all the weight of
> the build platform. I wasn't sure how well the nut
> would stay in place when tightened and I also
> needed nuts for the top of the shaft. Basically it
> was more money than I thought it was worth and I
> don't have much trouble with metric threads. I
> have just bought some a4 stainless m8 rod though
> which I'm hoping will help with waviness in the
> sides of parts and i'm upgrading to linear
> bearings.
> One other thing that might be useful is looking at
> 10x2 acme thread. You can buy flanged bearings
> that will fit in the orca frame but with a 10mm ID
> instead of 8mm. 10x2 thread and nuts are cheaper
> and should be stiffer as well.
> Pete
Sweet, i bougth 16 tooh pulley stock for the motors too, but 44 tooth pulley stock for the ends, my leadscrews cut to length, but without machineing the ends plus 6-flanged nuts where 15 euro plus shipping.
I think i will just go ahead and tap a 8mm acme thread in the pulleys, and fix them like that, but i still need a way of locking the leadscrews in place inbetween the top and bottom bearing, so that there is no backlash. that's my main hurdle, i was considering turning down the ends to a smaller diameter, and finding smaller bearings. and then milling the end where the pulleys goes to make a slot and locking it with this
www.lrparts.dk] (don't know the english word for them, halfmoon maybe?)
