T5 pulleys that aren't printed
May 06, 2012 03:18PM
Looking for some T5 pulleys and stumbled upon these:
[www.ebay.co.uk]
[www.ebay.co.uk]
Would they work better than printed pulleys, or does anyone know someone that sells to Europe.
thanks
Re: T5 pulleys that aren't printed
May 06, 2012 08:43PM
I use and sell something similar in NZ they work just fine, don't go less than 10 teeth though as it puts too much bend in the belt
__________________________________________________________________________
Experimenting in 3D in New Zealand
May 07, 2012 03:02AM
These are good in the UK.
[www.beltingonline.com]
TC
I should have pointed out that they do T2.5 as well.
Edited 1 time(s). Last edit at 05/07/2012 07:35PM by TCase.
May 07, 2012 07:17AM
They come in a range from 10 and up, what would be the optimal amount of teeth.
May 07, 2012 07:43AM
The more teeth, the lower the resolution, so go for the 10 tooth if you can get them. More teeth would give you more speed, though it takes more torque from the motor to deal with the larger pulley.
May 07, 2012 08:39AM
Thanks for the help, they do seem to come in 5.08mm pitch. Is this for clearance or will the .08mm gonna be a problem.
May 07, 2012 08:48AM
Thats bacause they are XL not T5, you will need XL belt. They also have 6mm bore while most steppers for reprap have 5mm shafts.
May 07, 2012 06:31PM
Or just order a T5 pulley from the site. They offer custom bores on T5 pulleys though it costs a bit more.
May 08, 2012 06:03PM
I ordered some from them too, i'm thinking the pulleys are essental to be completely circular.. they are the key parts to create a smooth flat print.. I tried printing out the pulleys but I always have a feeling that these crucial parts must be made with a more precise method.
