X "Walking" .3mm with each layer? May 11, 2012 03:14PM |
Re: X "Walking" .3mm with each layer? May 11, 2012 03:26PM |
FFF Settings Calculator | Gcode post processors | Geometric Object Deposition Tool Blog |
Tantillus.org | Mini Printable Lathe | How NOT to install a Pololu driver |
Re: X "Walking" .3mm with each layer? May 11, 2012 03:35PM |
Re: X "Walking" .3mm with each layer? May 11, 2012 03:47PM |
Re: X "Walking" .3mm with each layer? May 11, 2012 05:00PM |
Re: X "Walking" .3mm with each layer? May 11, 2012 05:21PM |
Re: X "Walking" .3mm with each layer? May 11, 2012 06:26PM |
Re: X "Walking" .3mm with each layer? May 11, 2012 07:19PM |
Re: X "Walking" .3mm with each layer? May 11, 2012 09:08PM |
Re: X "Walking" .3mm with each layer? May 11, 2012 09:37PM |
Re: X "Walking" .3mm with each layer? May 11, 2012 09:58PM |
Re: X "Walking" .3mm with each layer? May 11, 2012 10:10PM |
Re: X "Walking" .3mm with each layer? May 11, 2012 10:28PM |
Re: X "Walking" .3mm with each layer? May 12, 2012 04:45AM |
Re: X "Walking" .3mm with each layer? May 12, 2012 12:28PM |
Re: X "Walking" .3mm with each layer? May 12, 2012 03:23PM |
Admin Registered: 17 years ago Posts: 7,879 |
Re: X "Walking" .3mm with each layer? May 12, 2012 04:11PM |
Re: X "Walking" .3mm with each layer? May 12, 2012 05:20PM |
Re: X "Walking" .3mm with each layer? May 12, 2012 06:20PM |
Re: X "Walking" .3mm with each layer? May 12, 2012 06:26PM |
Re: X "Walking" .3mm with each layer? May 13, 2012 05:05AM |
Re: X "Walking" .3mm with each layer? May 13, 2012 06:30AM |
void do_step(int axis) { switch(axis){ case 0: WRITE(X_STEP_PIN, HIGH); break; case 1: WRITE(Y_STEP_PIN, HIGH); break; case 2: WRITE(Z_STEP_PIN, HIGH); break; case 3: WRITE(E_STEP_PIN, HIGH); break; } steps_taken[axis]+=1; WRITE(X_STEP_PIN, LOW); WRITE(Y_STEP_PIN, LOW); WRITE(Z_STEP_PIN, LOW); WRITE(E_STEP_PIN, LOW); }
if (counter_x > 0) { WRITE(X_STEP_PIN, HIGH); counter_x -= current_block->step_event_count; WRITE(X_STEP_PIN, LOW); count_position[X_AXIS]+=count_direction[X_AXIS]; } counter_y += current_block->steps_y; if (counter_y > 0) { WRITE(Y_STEP_PIN, HIGH); counter_y -= current_block->step_event_count; WRITE(Y_STEP_PIN, LOW); count_position[Y_AXIS]+=count_direction[Y_AXIS]; } counter_z += current_block->steps_z; if (counter_z > 0) { WRITE(Z_STEP_PIN, HIGH); counter_z -= current_block->step_event_count; WRITE(Z_STEP_PIN, LOW); count_position[Z_AXIS]+=count_direction[Z_AXIS]; } #ifndef ADVANCE counter_e += current_block->steps_e; if (counter_e > 0) { WRITE_E_STEP(HIGH); counter_e -= current_block->step_event_count; WRITE_E_STEP(LOW); count_position[E_AXIS]+=count_direction[E_AXIS]; } #endif //!ADVANCE
Re: X "Walking" .3mm with each layer? May 13, 2012 05:58PM |
Re: X "Walking" .3mm with each layer? May 13, 2012 10:29PM |
Re: X "Walking" .3mm with each layer? (Solved) May 19, 2012 10:49PM |
Re: X "Walking" .3mm with each layer? (Solved) May 20, 2012 09:27PM |
Re: X "Walking" .3mm with each layer? June 09, 2012 05:36AM |
Re: X "Walking" .3mm with each layer? June 09, 2012 06:00AM |
Admin Registered: 12 years ago Posts: 1,063 |
Re: X "Walking" .3mm with each layer? June 09, 2012 11:40PM |
Re: X "Walking" .3mm with each layer? June 12, 2012 08:31PM |
