First thing is to level your bed. If the bed surface is not absolutely flat, or close to it, you will need to use rafting on your prints.
Second thing is that you need to calibrate X, Y, and Z so that when you command an axis to move 100mm it moves exactly 100mm +/- 0.2mm
Third is to calibrate your extruder. Search for extrusion calculator.
