You might want to give it a big wide base manually so it is firmly attached to the bed, and attempt printing it straight up in two atleast two pieces. A toothbrush, well the ones I use, tend not to have any unprintable overhangs so it should be fine. If the model starts to wobble then you may want to slow it down, use Z lift and/or split it into several pieces.
Alternatively you can split it in half lengthways so it has a flat base and use a very low layer height to give it enough quality to have defined features.
Support is okay but will likely need postprocessing, which is fine if dimensions are not critical.
