please help - support in slicer
June 12, 2012 04:10PM
Hi
is there any solution for support in slicer... ? if not in which program can i add this feature ?
regards
elidor
Re: please help - support in slicer
June 12, 2012 04:35PM
Skeinforge
__________________________________________________________________________
Experimenting in 3D in New Zealand
June 12, 2012 05:22PM
In Slic3r 0.8.2 you find it in "Print Settings" - "Generate support material". Last time I tried (several versions ago) it was still quite experimental, and to quote the changelog (much work is still needed on support material), so don't expect too much.
Personally I design my parts to be printable without support, or add support struts manually in difficult cases. Still, for some parts generated support structure is probably the most sensible option, and I second NelsonRap with skeinforge being the solution in those cases.
-Nudel
Blog with RepRap Comic
June 12, 2012 06:53PM
there is a support feature in there now, but it dose not have any settings for it, so all it dose is a hex pattern
