I am using Repetier firmware on RAMPS with my deltabot. At the moment, I have two problems with it.
First of all, all the movements are painfully slow. No matter what t says in the Gcode, no matter the "max feedrate" settings in the firmware, it moves extremely slowly -- 10 mm/s, maybe. The individual steppers can spin quite quickly, but the printer doesn't want the effector to move at any reasonable speed.
Secondly, I can't get the automatic bed probe to work. When I try to compile with it enabled, I get this:
Commands.cpp: In static member function ‘static void Commands::executeGCode(GCode*)’:
Commands.cpp:651:13: error: ‘buildTransformationMatrix’ is not a member of ‘Printer’
Commands.cpp:654:26: error: ‘autolevelTransformation’ is not a member of ‘Printer’
Commands.cpp:654:62: error: ‘autolevelTransformation’ is not a member of ‘Printer’
Commands.cpp:655:26: error: ‘autolevelTransformation’ is not a member of ‘Printer’
Commands.cpp:655:62: error: ‘autolevelTransformation’ is not a member of ‘Printer’
Commands.cpp:657:26: error: ‘autolevelTransformation’ is not a member of ‘Printer’
Commands.cpp:657:62: error: ‘autolevelTransformation’ is not a member of ‘Printer’
Commands.cpp:658:26: error: ‘autolevelTransformation’ is not a member of ‘Printer’
Commands.cpp:658:62: error: ‘autolevelTransformation’ is not a member of ‘Printer’
Commands.cpp:660:24: error: ‘autolevelTransformation’ is not a member of ‘Printer’
Commands.cpp:660:60: error: ‘autolevelTransformation’ is not a member of ‘Printer’
Commands.cpp:660:96: error: ‘autolevelTransformation’ is not a member of ‘Printer’
Commands.cpp:660:132: error: ‘autolevelTransformation’ is not a member of ‘Printer’
Any ideas?
Edited 1 time(s). Last edit at 02/19/2014 09:14PM by epicepee.
