blown z outlet on arduino
Posted by 65c10restomod
August 25, 2014 04:23PM
the heat sink on the ramps 1.4 z stepper driver slid over and shorted out the pins and now the z isnt working .I have the problem narrowed down to the arduino pins for the z stepper .Is there some programming in the repetier firmware I can change that would allow me to use the z axis plugged in the second extruder outlet .
Edited 1 time(s). Last edit at 08/25/2014 04:24PM by 65c10restomod.
Re: blown z outlet on arduino
August 26, 2014 08:09AM
take a look in pins.h [github.com]
Find the section for your board, [github.com]
And swap the step, direction and enable pins from the e1 and Z definitions.
Compile, upload and cross fingers.
August 26, 2014 04:05PM
you will also want to look at the pin number and match it to this diagram
all the pins i/o on the port/channel that was blown wont work any more. perhaps they can work as inputs, you would need to check
[arduino.cc]
August 26, 2014 08:37PM
ill give it a shot
