Makerbase MKS Base Schematic May 05, 2015 12:02AM |
Re: Makerbase MKS Base Schematic May 05, 2015 09:52AM |
Re: Makerbase MKS Base Schematic May 05, 2015 11:33AM |
Re: Makerbase MKS Base Schematic May 05, 2015 11:19PM |
lunarkingdom
you can use the powered output from your ramps board to switch a relay and use a second power supply to heat your heatbed, your warm up times will be a lot shorter, whe I used one power supply it would take 15 minutes or more to reach 100c, once I went to two power supplies it takes 3-4 minutes now and that is for a 12 inch by 12 inch bed.
cdru
Or replace the polyfuse with a 15amp blade fuse.
Or use an external SSR to do the switching.
Or if you feel adventurous and want to press your luck without fuse protection, power the bed directly from your power supply, bypassing the fuse. Just use the RAMPS board to switch the ground.
If you want to make your own board based on the MEGA chip, just use a RAMPS schematic as a starting point. Or RAMBO. Or RUMBA. Just use better connectors, mosfets, and caps rated at 36V and you'll have a very solid 8-bit design.
Re: Makerbase MKS Base Schematic May 06, 2015 11:15AM |
The schematic is available but it basically useless as it's just some XPS (similar to PDF) files that shows the basic individual circuits, but the layout files are not available nor is the schematic available in a reusable form without completely recreating it. It's why there's the two big boxes at the top of it's wiki page that says it doesn't comply with the lowest common denominator of being called open source.Quote
tandukion
So, I really have to design it from scratch? with Arduino Mega and RAMPS Schematic as references.
It will really help me if I can find the schematic of MKS Base, haha
