Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 03, 2015 08:50PM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? May 03, 2015 09:32PM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? May 03, 2015 10:03PM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? May 03, 2015 10:33PM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 03, 2015 10:38PM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? May 04, 2015 01:05AM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 04, 2015 04:48AM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 04, 2015 07:39AM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 04, 2015 10:04AM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 04, 2015 11:39AM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 04, 2015 02:59PM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 04, 2015 03:07PM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 04, 2015 03:13PM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 04, 2015 03:18PM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 04, 2015 04:10PM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 04, 2015 04:23PM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 04, 2015 06:15PM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 09, 2015 12:33AM |
lunarkingdom
digital dentist, I am only using ABS on this printer as it is the only material strong enough for my needs and I do not plan on using anything else on it, my old 8x8 prusa i3 is about to be rebuilt to take ABS and ninjaflex but I will not be doing that until I find a hotbed solution that works for this 12x12 printer, thus this thread. I am leaning hevily toward using glass as I spent a considerable amount buying 10 sheets of 12x12 tempered glass and already have it in my inventory, IF it absolutly does not work I will not use it but I have had stellar adhesion using it and hairspray.
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 09, 2015 03:13AM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 09, 2015 09:28AM |
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 09, 2015 10:25AM |
the_digital_dentist
Why do you put glass on top of aluminum when you can print directly on the aluminum (with kapton tape)?
Re: Auto bed leveling, can I change it to use more than 4 corners to level the bed? Any better ways to get my bed level? It is warped! May 09, 2015 10:28AM |
