LCD display with card reader May 08, 2015 10:23PM |
Re: LCD display with card reader May 09, 2015 10:08AM |
Re: LCD display with card reader May 09, 2015 10:20AM |
Re: LCD display with card reader May 11, 2015 06:23PM |
gforce1
Connect a lcd with sd card slot to your ramps. Sent or copy via your slicing program the sliced gcode to your sd card. On the lcd you can than run the print from the sd card. You can also adjust some settings from your lcd, like homing, speed and temperatures.
Re: LCD display with card reader May 11, 2015 06:25PM |
Re: LCD display with card reader May 11, 2015 07:00PM |
Re: LCD display with card reader May 12, 2015 07:16PM |
the_digital_dentist
Speed control is the default for the rotary encoder after whatever you used it for last times out.
Just turn the encoder and you'll see the speed indicator on the screen go up or down. It usually takes a few seconds before the machine responds by actually speeding up or slowing down.
Re: LCD display with card reader May 13, 2015 04:48PM |
