Prusa i2 Won't Connect to PC Anymore.
Posted by chuttney1
May 31, 2015 03:30PM
So it seems like my Prusa i2 will no longer connect to my pc, I'm getting the COM 5 error. I cleared out all serial ports with the registry edit tip suggested on this forum while searching for an answer. That did not work. The only option I have is to use my brother's macbook or a linux dual boot pc done on an old laptop. Im not liking the macbook option because if the screen goes to sleep or your browsing the internet, it throws off error codes and pauses the print in process. I tried the option disconnect printer from pc, kill application, kill power for a few seconds, reconnect power, reconnect to pc, launch application. This does not work. Restarting computer does not work for this type of problem.
Re: Prusa i2 Won't Connect to PC Anymore.
June 01, 2015 01:49PM
Are you able to update firmware to the Arduino being used?
And what control board are you using?
Regards
NFireLabs - The World First Modular 3D Printer - At An Affordable Price!
June 12, 2015 08:31PM
The board Im using is ramps V1.4. The arduino software won't allow me to upload changes to the Mega2560.
June 26, 2015 11:57PM
Found the reason why it never connected and it was a drive issue with one of the programs and an update from Microsoft to correct it.
