Y axis randomly shifts in one direction when printing July 08, 2015 08:23PM |
Re: Y axis randomly shifts in one direction when printing July 08, 2015 09:16PM |
Re: Y axis randomly shifts in one direction when printing July 08, 2015 10:04PM |
Re: Y axis randomly shifts in one direction when printing July 08, 2015 10:07PM |
the_digital_dentist
Make sure the pulley on the motor is screwed down tight. Take off the Y axis belt and push the bed back and forth. It should move easily and smoothly throughout its range. You may have an intermittent connection between the driver and the motor- check the wiring carefully.
I wouldn't be too concerned about the discrepancy between the bed position and the LCD reading. The firmware doesn't read the encoder very quickly and it is easy to spin it too fast for Marlin to keep up.
Re: Y axis randomly shifts in one direction when printing July 08, 2015 10:20PM |
Neb4328
Can you explain further about the connection between driver and the motor, sorry Im new at 3d printing :/
Re: Y axis randomly shifts in one direction when printing July 09, 2015 07:25AM |
Re: Y axis randomly shifts in one direction when printing July 09, 2015 03:50PM |
kimented_
If you never do it, you must calibrate your stepsticks.
Maybe they are set too high, resulting on an overheating, or too low, then the motor do not have sufficient torque.
Re: Y axis randomly shifts in one direction when printing July 10, 2015 02:41AM |
Re: Y axis randomly shifts in one direction when printing July 10, 2015 09:01PM |
Re: Y axis randomly shifts in one direction when printing July 11, 2015 10:47PM |
Zerker
by stepstick he means the motor driver on your board.
Cheap motor drivers like the a4984 stepstick cuts out when it gets too hot, placing a heatsink ontop of the chip and a fan blowing on the heatsink will stop this unless youare puting too much current through your motor driver or are trying to move too fast.
have a look at these two pages
[reprap.org]
[reprap.org]
most people with RAMPS boards now use the pololu stepper drivers which can take more current (though around 1 amp you should probably at least use a heat sink)
