How to put ptfe tube into extruder tube.
Posted by SkeptikRC
September 19, 2015 03:05AM
Hey reprap forum, I have had to replace the ptfe tube in my geeetech prusa I3B after it was melted, my fault. I am trying to put the new ptfe tube in but it won't fit. Is there a trick to this?
Re: How to put ptfe tube into extruder tube.
September 19, 2015 06:45AM
Any picture ?
Be shure you own the proper tube diameter.
Even if inside diameter is 2mm, there's some 3 and 4 outside diameter.
If there's just a small difference that prevents you to insert the part,
you can heat the flange into boiling water
and cool down the insert into the freeser before instert it.
Metal shape can change when overheated.
Consider some parts are consumables,
and keep some stock of indispensable parts, like nozzle, heatbreaks...
++JM
