Re: Hello! January 01, 2016 05:07PM |
Re: Hello! January 01, 2016 05:50PM |
Re: Hello! January 01, 2016 06:12PM |
Re: Hello! January 01, 2016 06:18PM |
Re: Hello! January 01, 2016 07:16PM |
zsrevda
Print area is ~40x40x40cm... It`s on PC ,so my printer can be that big .... for now
Re: Hello! January 01, 2016 07:43PM |
Re: Hello! January 02, 2016 04:15AM |
Re: Hello! January 02, 2016 05:35AM |
Re: Hello! January 02, 2016 08:11AM |
Printing flexible filament with a bowden setup is just a question of the right extruderQuote
zsrevda
I consider bowden as solution, but for now i would like to stick to direct system, because of possible use of flex filament from time to time.
Re: Hello! January 02, 2016 08:31AM |
Re: Hello! January 03, 2016 04:13PM |
Re: Hello! January 03, 2016 07:37PM |
Re: Hello! January 04, 2016 03:50AM |
Re: Hello! January 04, 2016 07:17AM |
Re: Hello! January 05, 2016 06:24AM |
Re: Hello! January 05, 2016 07:15AM |
You simply will not be able to print at what i would care to term optimal speed.Quote
zsrevda
So just tell me simple for now. Would be an kilo,2 or 3kg, the max weight for optimal speed?
Re: Hello! January 05, 2016 01:25PM |
Re: Hello! January 05, 2016 04:32PM |
I think that is because you are trying to build a printer in a way that is just not geared towards beeing fast.Quote
zsrevda
I`m little confused.
Re: Hello! January 08, 2016 12:29AM |
Re: Hello! January 08, 2016 09:56PM |
Re: Hello! January 09, 2016 02:20AM |
Re: Hello! January 09, 2016 06:29AM |
Re: Hello! January 10, 2016 11:05AM |
Re: Hello! January 10, 2016 11:10AM |
You are aware that this will not help if you are not working against gravity? There is no free lunch in physicsQuote
zsrevda
P.S. Future toughts: z will be light "as feather" with counterweights like in building elevators.
Re: Hello! January 10, 2016 12:32PM |
i think the bending will be less problematic at this new weight also.
Re: Hello! January 10, 2016 12:34PM |
Explain this a little bit here please.Quote
Srek
plankton
excellent, that's the weight dealt with... now what to do with all that pesky mass
