H-bridge chip selection
Posted by strikom
July 31, 2012 07:18AM
Hi, I am new with the stepper motor interfacing circuits and I was looking online and came across quite a few. I just wanted to know whether I should be aware of any issues with using an Allegro UDN2988 H-bridge chip to drive a bi-polar stepper motor using a PIC 16F84 microcontroller.
Re: H-bridge chip selection
July 31, 2012 07:27AM
Correction : thats UDN 2998
July 31, 2012 08:14AM
It should work with a 5V PIC but it will only give full or half stepping constant voltage drive. If you are using this for a RepRap you will want microstepping and constant current drive.
It is also classed as obsolete by the manufacturer.
Edited 1 time(s). Last edit at 07/31/2012 08:15AM by nophead.
July 31, 2012 08:20AM
Can you please suggest any alternative ICs that i can instead
July 31, 2012 09:13AM
Most repraps use modern Allegro chips like A4988 but, because it is surface mount, tend to buy them ready mounted: [www.pololu.com].
Those that prefer to solder their own or want a bit more current use the Toshiba TB6560AHQ but it has some nasty power cycling requirements that most people ignore.
