When using resistors for inductive prox sensor, do they effect range?
Posted by VTE
VTE
April 05, 2016 06:50PM
I am using an inductive proximity probe for ABL and I want to boost its range, do the voltage divide resistors effect this? If I use a 100 and a 150, is there a better combination out there? I also measure 3.4v on the hi side, this is a little low on the voltage, should I be using different resistors?
Edited 1 time(s). Last edit at 04/05/2016 06:51PM by VTE.
Re: When using resistors for inductive prox sensor, do they effect range?
April 05, 2016 07:42PM
Range is dependent on sensor design, and material being sensed (longest with steel or iron, lower with aluminum). It can be influenced by supply voltage, you are better off being on the higher side of the range. Nothing you can do with a voltage divider will boost the range of the sensor.
April 06, 2016 12:55AM
Divider formula is as follows: Vout = Vin x R2 / R1 + R2
