i think that will help you. Works fine for me.
(copied from
here)
StathisD
Hi I had the same error... After fiddling around (thankfully I'm a developer) I changed the
code like this in dogm_font_data_marlin.h
//#include utility/u8g.h
#include clib/u8g.h
I removed the smaller /greater symbols because they're being deleted in this post. In the code you should keep these symbols
there are 2 places that the .h file is referenced,
In my case I just replaced the stepper drivers with DRV8825 ones ( old A4988 were dying one after the other) ad I had to recompile the FW with the new steps/mm for all motors.
The problem is you're using the latest u8g library and the directory structure changed. (utils directory is gone)
Don't forget to include the library in the Marlin.ino (Sketch->include library->u8glib)
Usually you cannot just "weed out" the include files, this .h file is part of the marlin solution.
Regards, Stathis D.
Siggi
Geeetech I3 Pro B 8mm Acryl - Mega 2560 - Ramps 1.4 - TMC2100 - MK42 - E3DV6-Clone 0,4 - SSR 522-1dd60-40 (A-Senco) - Marlin RC8Bugfix 26.12.2016 - Repetier Host - Windows 7 64 Bit
Vulcanus mit Linearschienen
Anycubic i3 Mega
