Neat JHead wiriing examples
August 05, 2012 06:40AM
Hi guys
just wondering if you can post some nice clean examples of Wiring a J-Head
im looking for connects used, what type and gauge of wire , Wire heat protection, Wire placement (resistor and also thermistor), quick change options on wiring also. as i want to easily switch between .5 for parts and .35 for art
just redoing my .5mm h-head nozzel after cleaning it up and trying to get it nice a neat.
just as a note iv seen on the mendel 90 it uses a 9pin d connector for the extruder assembly. this never carries the jhead power as well does it ? what amp would you say the j-head uses ?
Re: Neat JHead wiriing examples
August 05, 2012 02:34PM
Yes it powers the J-head. The heater should take 2A or less.
August 06, 2012 07:20AM
can any one suggest some nice 2A connectors and plugs ? (UK if possible farnell even better)
also wire im thinking PTFE teflon coated wire? trouble is i see it on ebay but only lists thickness of wire not rating in amps
August 06, 2012 07:58AM
D type connectors handle 2A or more per pin, that is why I use them.
August 07, 2012 01:42PM
lol didnt know they went that high. d sub it is!
any suggestions on wire thickness?
August 07, 2012 05:19PM
Some are 2A, some 5A and some 7A. It depends on the contact material.
The heater wires should be at least 22 AWG I think.
August 07, 2012 06:53PM
NumberSix just shared a nice link of his Jhead assembly in another post
[numbersixreprap.blogspot.ie]
-Rob A>
