Inverted FFF printer May 18, 2016 01:51PM |
Re: Inverted FFF printer May 18, 2016 01:58PM |
Re: Inverted FFF printer May 18, 2016 02:52PM |
Koko76
Support structures would have to be done differently, you can't count on plastic falling onto them for a looser bond. Gravity will cause semi soft plastic to
sag down towards the print head in addition to the curling effect that can happen with a traditional setup. It would be interesting to try, but I worked through these and a few other downsides before coming to the conclusion it wasn't worth it for me to try.
Re: Inverted FFF printer May 18, 2016 05:08PM |
Re: Inverted FFF printer May 18, 2016 05:45PM |
the_digital_dentist
How can you print support material for prints that need it? If you print it close enough to the print layer that it will work to provide support, you won't be able to separate it from the print.
Re: Inverted FFF printer May 18, 2016 09:26PM |
Re: Inverted FFF printer May 18, 2016 11:00PM |
JamesK
As you said, I'm guessing the issue is that when things go wrong stuff will head towards the hotend instead of away from it. Bridging might be troublesome for that reason.
Re: Inverted FFF printer May 22, 2016 06:27AM |
Re: Inverted FFF printer May 22, 2016 01:25PM |
Druwan
I don't think it's a good idea, did you consider what will happen if a print falls on the extruder? My guess is that it will melt, ruin your extruder, and will catch fire.
Re: Inverted FFF printer May 22, 2016 01:48PM |
Re: Inverted FFF printer May 22, 2016 02:00PM |
LoboCNC
Yes, the print falling on the extruder would make a mess, but at <250deg.C, nothing will actually be ruined or catch fire (other than the print). I've been mulling over making a shroud/duct to cover up most of the extruder body with just the nozzle tip exposed through a clearance hole. I might also make a simple optical sensor to detect anything falling on the extruder head and wire that into the e-stop.
DD
what sort of problems do vibrations cause in uninverted printers, and is it gravity that causes extruders to drool or expansion of heating/melting filament?
Re: Inverted FFF printer May 22, 2016 04:12PM |
the_digital_dentist
Getting back to the original post, what sort of problems do vibrations cause in uninverted printers, and is it gravity that causes extruders to drool or expansion of heating/melting filament? Can either problem be fixed by inversion without introducing, new, possibly more severe problems?
Re: Inverted FFF printer May 22, 2016 05:03PM |
Re: Inverted FFF printer May 22, 2016 07:03PM |
the_digital_dentist
It seems like an awful lot of trouble to avoid building a rigid frame and in the end the printer won't be any lighter weight, cheaper, or more portable.
Re: Inverted FFF printer May 23, 2016 02:56PM |
Re: Inverted FFF printer May 23, 2016 05:03PM |
Re: Inverted FFF printer May 23, 2016 05:52PM |
Re: Inverted FFF printer May 24, 2016 04:29AM |
Re: Inverted FFF printer May 25, 2016 04:32PM |
Re: Inverted FFF printer May 25, 2016 05:13PM |
Druwan
Another disadvantage: heated plate. If you're not using a fully enclosed printer the heated bed would be totally useless as it won't help keeping higher layers warm. Even with 5 sides closed printers that's a problem, and fully enclosing a printer has other disadvantages. I'm pretty interested on what the outcome would be on parts that require supports, altough i think we would have the same problem. also i'm thinking about thin features with high angles that usually bend and are struck by the extruder. If they bend up while being affected by gravity, what happens when the gravity itself helps the process?
ps: sorry for my english, still trying to improve
Re: Inverted FFF printer June 16, 2016 06:17PM |
Re: Inverted FFF printer June 16, 2016 06:30PM |
Re: Inverted FFF printer June 16, 2016 07:24PM |
LoboCNC
I've got some initial printing results! Having watched miles of filament print over the last couple of years, so far, printing upside-down looks just like printing right-side up. The treefrog print, which has some steep overhangs, printed the same as on my conventional printers. Even my bridging test - ranging from 4mm to 34mm - came out pretty much the same. I'm sure longer bridges would cause trouble, but I'd never really want an unsupported bridge longer than 20mm anyway. So far, the 2 main drawbacks are: 1) poor visibility of what you are trying to print and 2) you have to manually wipe the extruder's nose when doing any sort of priming. The payoff, though, is that I've got a rock-solid printer (sorry about the pun) with very little structure. I've got accelerations set to 3000mm/s/s and the jerk set to 20, and I'm getting very smooth prints even though the heated bed is suspended from fairly spindly 12mm rods.
Re: Inverted FFF printer June 16, 2016 07:36PM |
This could be detected with some weight sensor on the bed and then stop the print.
Re: Inverted FFF printer June 16, 2016 07:50PM |
Re: Inverted FFF printer June 16, 2016 08:05PM |
ipcalit
Hmm, the frog looks nice, but... shouldn't the bridge be bending "upwards" if printed upside down?
Re: Inverted FFF printer June 16, 2016 08:09PM |
JamesK
That's a neat idea. Tricky at the beginning of a print when there isn't much added weight, but it will get progressively easier as the print progresses. The piezo sensors might even work for this as they respond quite well to sudden changes.
Re: Inverted FFF printer June 16, 2016 08:14PM |
LoboCNC
ipcalit
Yeah, it is actually kind of peculiar. As it printed the first bridging layer, the filament did sag down a little as you'd expect. But when the next layer went down (er, up), it pushed the bridging layer away so the net result looked very much like conventional bridging. I'll try to get a video of the bridge printing, but it's pretty tricky seeing exactly what's going on thru the small gap under the build plate. I'll try moving the print to the edge for a better view.
Re: Inverted FFF printer June 17, 2016 05:53PM |
Re: Inverted FFF printer June 17, 2016 06:01PM |
