E3D V6 Temperature drop mid print February 06, 2017 11:55PM |
Re: E3D V6 Temperature drop mid print February 07, 2017 01:21AM |
Re: E3D V6 Temperature drop mid print February 07, 2017 02:40AM |
Re: E3D V6 Temperature drop mid print February 07, 2017 06:29PM |
nebbian
The biggest problem here is the Kd, it's way too high. Drop your Kd to 20, double your Kp, and see what happens. I've found autotune of hotends to be pretty useless without manual tuning afterwards.
Re: E3D V6 Temperature drop mid print February 07, 2017 08:33PM |
o_lampe
I've printed PETG with the regular thermistor.
Is the new probe far from the original probe or does it get fresh air?
Can you print something with PLA and see if that works?
Re: E3D V6 Temperature drop mid print February 07, 2017 09:12PM |
Re: E3D V6 Temperature drop mid print February 07, 2017 10:17PM |
Re: E3D V6 Temperature drop mid print February 07, 2017 11:35PM |
nebbian
Hmm that's odd. Is the max PWM value in firmware set to something other than full power?
Edit: EXT0_PID_MAX in repetier, should be 255.
PID_MAX (or BANG_MAX, one is defined by the other) in Marlin, should be 255.
Re: E3D V6 Temperature drop mid print February 08, 2017 01:06AM |
Re: E3D V6 Temperature drop mid print February 08, 2017 01:28AM |
JamesK
For any extruder temperature oddity, it's worth checking the crimp connections between the solid core wires from the cartridge and the multi-strand used for the bulk of the connection. I've had multiple heaters with intermittent connections that were easily fixed by re-crimping.
Re: E3D V6 Temperature drop mid print February 08, 2017 07:28AM |
Re: E3D V6 Temperature drop mid print February 08, 2017 10:13AM |
mrmuffin
The new probe is glued into a M3 nut which is then screwed into the heater block. I am sure that the thermistor is reading properly in it's current position. I also tried printing PLA and got the same results. The heater is able to reach the right temperature yet it cannot keep it there once the print starts. If I stop the print though, the temperature will begin to rise back to the set value. Could this be an issue with the firmware?
Re: E3D V6 Temperature drop mid print February 08, 2017 11:35AM |
Re: E3D V6 Temperature drop mid print February 08, 2017 04:59PM |
Re: E3D V6 Temperature drop mid print February 09, 2017 07:11PM |
