What can cause this? (I may have an answer) May 23, 2017 06:22PM |
Re: What can cause this? (I may have an answer) May 23, 2017 06:44PM |
Re: What can cause this? (I may have an answer) May 23, 2017 10:04PM |
Re: What can cause this? (I may have an answer) May 24, 2017 02:18AM |
Re: What can cause this? (I may have an answer) May 24, 2017 07:05AM |
Re: What can cause this? (I may have an answer) May 24, 2017 09:41AM |
MCcarman
I have some suspicions that water absorption causes this. It is only a suspicion.
You are clearly extruding enough material for it to "squish" and its obviously hot enough to flow and to bond with its neighbour. So why does it not stick to the bed?
Hence I suspect there are small bubbles trapped under the filament that expand and cause it to lift.
Re: What can cause this? (I may have an answer) May 24, 2017 10:48AM |
Origamib
MCcarman
If it is too squished, the new bead being laid down will push out and away from the other lines, causing it to 'bubble'. Since the error accumulates, the new bead can actually be forced over by more then the width of the nozzle meaning the tip can't 'iron' it down as well.
I have had problems with PLA and ABS with too much moisture, but the first layer still looks the same. Adhesion can be affected but not this obviously. Also, you would hear a lot of popping and cracking.
Re: What can cause this? (I may have an answer) May 24, 2017 11:14AM |
Re: What can cause this? (I may have an answer) May 24, 2017 02:08PM |
Origamib
I highly doubt you have humidity issues in your spools in Colorado...
I keep my spools in large Tupperware boxes filled with orange/green desiccant. It changes colour when it has taken on too much water, and then I bake it in the oven to renew it. Silica gel can also be baked to renew it but you won't know when. its ready. The popping is the moisture in the filament boiling, expanding and finally released as steam out the nozzle. This can cause zits and over/under extrusion for a very small distance afterwards. For it to cause layer issues like this, your nozzle would probably sound like a kettle boiling!
Do you use a pcb heater? If so, these warp with every heating and cooling cycle and can put the bed off quite dramatically after only a few prints. 4 point levelling has a similar issue. Maybe invest in a better bed. I use 5mm tooling plate.
