Bed Leveling
August 22, 2012 04:52PM
The diagram shows a top view of the heatbed on my Prusa Mendel. S = the position of three adjustment screws for leveling the bed. The spots are the test results with green = good and red = poor.
My heatbed is glass then aluminimum then PCB then lasercut wood.
I don't see a way to correct the problem using just the screws. Any suggestions on how I can get it level? Shims under the glass perhaps?
Thanks, Andy
Edited 1 time(s). Last edit at 08/22/2012 04:53PM by ajayre.
open | download - BedLeveling.jpg (7.5 KB)
Re: Bed Leveling
August 22, 2012 05:05PM
why glass alu and pcb.....? the alu only deflects the heat
i would remove the alu as that can be deformed then use the glass right on the pcb and measure again
Re: Bed Leveling
August 22, 2012 05:17PM
why are you using only 3 screws to hold the bed ? prusa I2 uses 4 screws to hold the heated bed to bottom plate then the glass is held on using bulldog clips
you can then alter the height in each corner is needed but normally i dont see why you would. if your prusa frame is all level then the base should be level therefore the heated bed. i dont use springs i just raise the bed 4 m4 nuts form the bottom plate and bolt it down tight.
if you dont want to alter your setup the other way i can think is the alter the frame it self on the foot vertex move the vertical rod up and down will alter height in the corners.
Re: Bed Leveling
August 22, 2012 05:32PM
To answer the questions - I don't know why aluminium and three screws. It's a kit from RepRapPro aka Adrian Bowyer and I assumed there is a good reason it is why it is.
It's not a large variation towards the problem corner, just enough to make adhesion poor on the first layer.
Andy
Edited 3 time(s). Last edit at 08/22/2012 05:34PM by ajayre.
Re: Bed Leveling
August 22, 2012 05:41PM
It uses three screws because four screws over-constrains the bed. With four screws it is easy to make the bed warped. With three screws the bed will always be flat. If you want to level your bed as you have it shown there, simply lower the bottom left screw point and raise the right screw point.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
Re: Bed Leveling
August 22, 2012 06:09PM
I just skimmed through so not sure how helpful this will be but I would put the side that has two adjustment screws parallel to the x axis, from what I can see that would make adjustment easier.
Re: Bed Leveling
August 22, 2012 06:20PM
I would bet the issue is the Y rails not being parralel, so the bed twists as it moves end to end.
Re: Bed Leveling
August 22, 2012 11:44PM
I recommend reading this. Mostly, just print (or otherwise acquire) the thumb screws. I have them on mine with the four screw setup. Leveling was a cinch; I placed a sheet of paper on my print bed and used pronterface to move my extruder to each corner and the middle of the plate. Just turn the thumbscrews until you can move the paper from under the nozzle with just a bit of resistance.
Re: Bed Leveling
August 23, 2012 06:32PM
That method involves four screws, but my question is how to use the three screw system.
Re: Bed Leveling
August 23, 2012 06:33PM
Thanks for the suggestions. I understand that four screws could warp the bed, but perhaps it is already warped and I need to apply the opposite warp to get it back into shape? I'll try adjusting the two screws as suggested by Cameron.
Andy
FatFreddie
Re: Bed Leveling
August 25, 2012 09:57AM
If you adjust any screw, it makes the bed pivot about about a line between the other two screws. So, in the case above, I would start by altering the bottom left screw.
Re: Bed Leveling
August 25, 2012 06:37PM
Ah - yes, of course - now I can picture it in my head what an adjustment to one screw will do. Thanks!
Andy
