[ cynical mode ]
And you want us to do your work for you?
Maybe a incentive like a free probe to the best working solution would help to motivate us who don't get payed for this.
[ /cynical mode]
two pin endstops are normally gnd and signal.
Can find no information on this other than a name "Creality Cr-10 3D Printer Motherboard"
I would take a good look at the USB/vreg jumper. As an educated guess the pins are probably: 5v from vreg, input to main board 5v bus, 5v from usb. If so you could make up a two pin connector to replace the jumper, that takes power, and connects it to usb or vreg just like the jumper did. (or just solder a wire to the jumper)
Edited 8 time(s). Last edit at 10/11/2017 06:51PM by Dust.
