Shrinking issue
Posted by thedude
Shrinking issue
September 01, 2012 06:11PM
Hi fellow RepRappers!
I'm having some issues on large prints. The first few layers tend to shrink a lot during the print (while the following layers remains ok). A picture is worth a thousand words, so here it is:
This issue does not happen on smaller prints.
I'm printing PLA with a Mendel. The heated glass is set to 65 and the hot end to 185.
Any help would be much appreciated!
Theo
VDX
Re: Shrinking issue
September 02, 2012 03:35PM
... reduce the temperature of the heated bed - this 'elefant-foots' are an effect of too much heat while printing the first layers ...
Viktor
Re: Shrinking issue
September 09, 2012 04:23PM
I concur. Drop down a few degrees at a time till the problem goes away. I had the same problem with ABS prints I found 5c made the difference,
