Flexible Bed for any 3d printer April 04, 2018 04:09PM |
Re: Flexible Bed for any 3d printer April 05, 2018 09:15AM |
Re: Flexible Bed for any 3d printer April 05, 2018 10:57PM |
Re: Flexible Bed for any 3d printer April 06, 2018 05:00AM |
Re: Flexible Bed for any 3d printer April 06, 2018 09:05AM |
Re: Flexible Bed for any 3d printer April 07, 2018 03:56AM |
Admin Registered: 13 years ago Posts: 7,003 |
Re: Flexible Bed for any 3d printer April 08, 2018 04:02AM |
Re: Flexible Bed for any 3d printer April 08, 2018 06:58AM |
what I envisage, is the kit comes with two magnetic sheet with a 3M sticky backing one for the bed and the second with PEI sheet attachedQuote
deckingham
Given that most beds have some form of heat spreader which needs to be a good conductor of heat, these tend to be aluminium and not ferrous metal. So how is a flexible magnet going to adhere then?
Re: Flexible Bed for any 3d printer April 08, 2018 09:44AM |
Re: Flexible Bed for any 3d printer April 09, 2018 06:04PM |
Re: Flexible Bed for any 3d printer April 11, 2018 03:36PM |
Re: Flexible Bed for any 3d printer April 11, 2018 04:05PM |
andornot
I am looking for a beta tester of this product anybody interested?
Re: Flexible Bed for any 3d printer April 15, 2018 04:34AM |
Re: Flexible Bed for any 3d printer April 17, 2018 02:07PM |
Re: Flexible Bed for any 3d printer April 18, 2018 05:05PM |
I have a magnetic setup in use for a year or so now. You can use 3M foil to stick basically antything to a ferro or megetic foil, i use an Ultem sheet. The magnetic foil is actually improving the heat spreading, it is more even with than without.Quote
deckingman
Magnetic?
Just checked, and no this wasn't posted on 1st April.
Re: Flexible Bed for any 3d printer April 20, 2018 03:22AM |
Srek
deckingman
Magnetic?
You can either use magnetic / magnetic, magnetic / ferrofoil or magnetic / steel sheet. I use the steel sheet as a base for any material that needs glue to stick.
Re: Flexible Bed for any 3d printer April 20, 2018 03:59AM |
Re: Flexible Bed for any 3d printer April 20, 2018 04:26AM |
Re: Flexible Bed for any 3d printer April 20, 2018 05:34AM |
You can find an image here [forums.reprap.org]Quote
andornot
Srek
deckingman
Magnetic?
The 3m foil is this magnetic part. What temperatures can magnets take? Do you have a picture of your setup?
Andrew
Re: Flexible Bed for any 3d printer April 20, 2018 07:18AM |
Srek
andornot
Srek
deckingman
Magnetic?
Andrew
The foil stands up to more than 110° without losing magnetism.
Re: Flexible Bed for any 3d printer April 20, 2018 04:29PM |
Re: Flexible Bed for any 3d printer April 22, 2018 02:33PM |
Re: Flexible Bed for any 3d printer April 23, 2018 02:01AM |
Re: Flexible Bed for any 3d printer April 23, 2018 05:46AM |
o_lampe
I thought, the magnet foil could have a cut off at one or two corners, where we could push a knife or spatula between the foil and the workplate?
Re: Flexible Bed for any 3d printer April 24, 2018 02:52AM |
Re: Flexible Bed for any 3d printer April 24, 2018 12:18PM |
Re: Flexible Bed for any 3d printer April 27, 2018 02:52AM |
Re: Flexible Bed for any 3d printer April 27, 2018 01:20PM |
Re: Flexible Bed for any 3d printer April 28, 2018 04:16AM |
