Strange stepping issue
September 11, 2012 04:39AM
I have a Sells Mendel running Gen6
I used to run it off an old desktop just fine using Repsnapper, when that died I switched to running it off a netbook and that is when this issue started.
About 60% of my prints now step over after a few layers mostly on the Y axis but sometimes on the X axis too. Often they step back after about 6-10 layers leaving a ridge on the print.
I changed back to running off a different desktop and tried printing a box the Y axis printed about 5 layers perfect then started stepping over, this time it never came back.
Is this likely to be a motor issue or an electronics issue, I have a spare Sanguino board that I have been making to run a SD card is this likely to fix my stepping issue as I am at a total loss as to whats causing it.
Gary
__________________________________________________________________________
Experimenting in 3D in New Zealand
Re: Strange stepping issue
September 11, 2012 04:15PM
Anyone? I'm kinda getting desperate as I can no longer rely on my printer to make decent prints and I'm not sure what my next step should be
September 11, 2012 04:20PM
Could it be your USB messing up the connection?
Try using a different computer. From your description it seems all that has changed is your computer, and the weak link there is the USB connection.
September 11, 2012 04:24PM
Your missing steps, it's either a mechanical issue, i.e. one of your axis takes more force to move than the steppers are providing.
Lubricate the axis, if that doesn't fix it try turning the pots on the stepper drivers up very slightly, and by slightly I mean as little as you physically can.
It could also be an electrical issue
Loose connection
Electrical noise
or any number of other things, but I'd start by assuming it's mechanical.
September 11, 2012 04:37PM
> connection.
Yes the original computer died and this issue is now happening on 2 different ones, I'm looking around for a shielded cable I know I have one somewhere
September 12, 2012 06:23PM
Assuming that you've already checked for a mechanical problem ...
Could it be a power-saving feature powering down the USB after a few minutes?
September 13, 2012 04:05AM
Hmm could be I do remember disabling that on the original desktop and the screensaver. I have done the screensaver on this new computer but forgot about the power saving function on ports will have to have a look
September 16, 2012 02:16AM
Nope not a power down issue, and not a heat issue either as had a desk fan blowing on the Gen6 today and it still stepped on layer 4 damn annoying and mechanically everything is fine, so time to finish the sanguino board
September 16, 2012 04:58AM
It looks like a power surge due to switching of a the lamp load. Try with a ferrite torus in both your USB and power supply cables. Two turns of cable through the torus is better than just going through.
September 16, 2012 04:13PM
> through.
Any idea where I can get some?
September 16, 2012 04:27PM
Some USB cables do have it built in (these bulges [www.computeractive.co.uk] ). Some electronic equipment may have it too. You can get them on eBay and I guess on RadioShack too.
September 17, 2012 03:55PM
After much thinking I realised the freezer is on the same circuit, but haven't had time to see if it is what's causing the issue
September 17, 2012 04:31PM
Have you tried printing from SD? I know, "bbbbut... it's not convenient"...I get it. But have you tried it that way? If you are having issues with the communications, then that should resolve it.
Since it would be resolved under those circumstances, then you would have a pretty good assurance the issue IS communications rather than something other mechanical or electrical issue directly associated with the printer itself, leading to better understanding than stumbling about blindly in the dark groping for something that may or may not even be the issue.
September 18, 2012 01:51AM
Not yet because my only SD capable card is finished yet
September 18, 2012 02:05AM
The step signals are generated by the microprocessor, so USB communications would not be a likely culprit, unless you are using Win7 64-Bit.
You can evaluate your machines tendency to skip steps by loading each axis up with some weight, and observing how it runs. On the y axis you can stack books or magazines until it stalls. If the problem is too little current, or binding, it will turn up right away. If the problem is over current/over temp protection kicking in on the drivers, it may take a while moving for the problem to show.
September 18, 2012 03:58PM
Thanks will have a try at the weekend, using XP 32bit
