Steps per mm vs theoretical resolution November 26, 2018 09:43PM |
Re: Steps per mm vs theoretical resolution November 26, 2018 09:59PM |
Admin Registered: 13 years ago Posts: 7,002 |
Re: Steps per mm vs theoretical resolution November 26, 2018 10:08PM |
Re: Steps per mm vs theoretical resolution November 26, 2018 10:12PM |
Re: Steps per mm vs theoretical resolution November 26, 2018 11:23PM |
Re: Steps per mm vs theoretical resolution November 27, 2018 02:47PM |
Admin Registered: 16 years ago Posts: 13,889 |
Re: Steps per mm vs theoretical resolution November 29, 2018 04:25AM |
Re: Steps per mm vs theoretical resolution November 29, 2018 07:45AM |
imqqmi
If a full rotation of the 20 teeth pulley covers 40mm, ie 20 teeth at 2mm per tooth, the number of steps a 1.8 degree per step stepper motor needs to do for 1mm is 200 steps per full rotation / 40mm per rotation= 5 steps per mm. so a single full step covers 1/5 = 0.2mm.
Re: Steps per mm vs theoretical resolution November 30, 2018 02:37AM |
Re: Steps per mm vs theoretical resolution December 01, 2018 09:24AM |
imqqmi
2x and 4x microstepping is also reasonably accurate so you could push it to 0.1 and 0.05mm per layer.
Re: Steps per mm vs theoretical resolution December 01, 2018 10:48AM |
Re: Steps per mm vs theoretical resolution December 01, 2018 11:22AM |
Re: Steps per mm vs theoretical resolution December 02, 2018 02:49AM |
PDBeal
In my case, these are only going on my Z axis, so speed isn’t going to be an issue.
