Motors not functioning August 01, 2019 04:30PM |
Re: Motors not functioning August 01, 2019 05:35PM |
TehCookie1
I have a ramps 1.4 for a diy 3d printer. so far I have everything wired and firmware set up, but I ran into a problem.
I couldn't move any axis. they just vibrated a little and stopped. I used the test code to calibrate the current going to the motor according to the wiki, but still the same result.
even adjusting the current to the maximum only caused the motor to heat up. I even got a new set of a4988 drivers, but still no difference. everything else worked nicely. I tried it with octoprint and pronterface.
I also tried reinstalling the firmware (Marlin), but still no change. the endstops were also working as intended. Homing the axis (still no movement) would only result in this error: Error: Printer halted. kill() called
Re: Motors not functioning August 01, 2019 06:03PM |
Re: Motors not functioning August 01, 2019 06:57PM |
Re: Motors not functioning August 01, 2019 11:00PM |
TehCookie1
I confirmed the wiring was correct by running the test code. I suspect that there is something wring with the software side.
Re: Motors not functioning August 02, 2019 10:41AM |
Re: Motors not functioning August 02, 2019 11:12AM |
Admin Registered: 13 years ago Posts: 7,004 |
Re: Motors not functioning August 02, 2019 11:34AM |
Re: Motors not functioning August 02, 2019 11:47AM |
Re: Motors not functioning August 02, 2019 12:58PM |
Re: Motors not functioning August 02, 2019 07:24PM |
