SKR1.3 I/O Pins not working October 06, 2019 11:03AM |
#define NEOPIXEL_LED //MS #if ENABLED(NEOPIXEL_LED) #define NEOPIXEL_TYPE NEO_GRBW // NEO_GRBW / NEO_GRB - four/three channel driver type (defined in Adafruit_NeoPixel.h) #define NEOPIXEL_PIN P1_24 //MS BOOKMARK SKR LED driving pin #define NEOPIXEL_PIXELS 49 ... #define PRINTER_EVENT_LEDS ...
#define CASE_LIGHT_ENABLE //MS #if ENABLED(CASE_LIGHT_ENABLE) #define CASE_LIGHT_PIN P1_24 //MS BOOKMARK SKR Override the default pin if needed #define INVERT_CASE_LIGHT false // Set true if Case Light is ON when pin is LOW #define CASE_LIGHT_DEFAULT_ON true // Set default power-up state on #define CASE_LIGHT_DEFAULT_BRIGHTNESS 127 //MS Set default power-up brightness (0-255, requires PWM pin) #define CASE_LIGHT_MENU //MS Add Case Light options to the LCD menu //#define CASE_LIGHT_NO_BRIGHTNESS // Disable brightness control. Enable for non-PWM lighting. #define CASE_LIGHT_USE_NEOPIXEL //MS Use Neopixel LED as case light, requires NEOPIXEL_LED. #if ENABLED(CASE_LIGHT_USE_NEOPIXEL) #define CASE_LIGHT_NEOPIXEL_COLOR { 0, 0, 0, 127 } //MS { Red, Green, Blue, White } #endif #endif
#define E0_AUTO_FAN_PIN P1_28 //MS BOOKMARK SKR #define E1_AUTO_FAN_PIN P1_26 //MS BOOKMARK SKR #define E2_AUTO_FAN_PIN -1 #define E3_AUTO_FAN_PIN -1 #define E4_AUTO_FAN_PIN -1 #define E5_AUTO_FAN_PIN -1 #define CHAMBER_AUTO_FAN_PIN -1 #define CHAMBER_AUTO_FAN_PIN -1 #define EXTRUDER_AUTO_FAN_TEMPERATURE 55 //MS #define EXTRUDER_AUTO_FAN_SPEED 255 // 255 == full speed
Re: SKR1.3 I/O Pins not working October 06, 2019 11:57AM |
Admin Registered: 13 years ago Posts: 7,012 |
Re: SKR1.3 I/O Pins not working October 06, 2019 01:17PM |
Re: SKR1.3 I/O Pins not working October 06, 2019 08:11PM |
Re: SKR1.3 I/O Pins not working October 07, 2019 04:19AM |
