Well my printer has finally got the upper hand. I bought an Aurora printer a while back, I upgraded the extruder with a geared one, worked well, I built a glassed in cabinet, added bed leveling etc.etc., finally got it working well. Today when I turned it on there was a noise from the power supply and everything went dead, found a cut and shorting wire for the leveling sensor, replaced cut wire and installed new power supply, turned it on everything seemed ok except the lcd showed temp error for both bed and extruder, all fans worked as well as the z sensor but everything else is dead, I dont know enough about electrical boards to troubleshoot. I started looking at new boards, but I wouldnt know where to start with all the boards out there.
Might be time to kick it to the curb and find a new hobby ! What do you think ?
Terry
