It looks CLEAN
Who Has Built an Ecksbot? It looks CLEAN October 03, 2012 01:38AM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 03, 2012 08:06AM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 03, 2012 10:27AM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 03, 2012 02:53PM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 03, 2012 07:32PM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 03, 2012 10:38PM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 03, 2012 11:06PM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 04, 2012 06:49AM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 04, 2012 07:04AM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 04, 2012 07:18AM |
). Having the z on top this can not happen. Making sure that the coupling does not come loose is much easier than getting rid of z-wobble with M8 threaded rods, isn't it?
Re: Who Has Built an Ecksbot? It looks CLEAN October 04, 2012 08:21AM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 04, 2012 08:28AM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 04, 2012 09:13AM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 04, 2012 09:16AM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 05, 2012 10:32PM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 05, 2012 11:31PM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 06, 2012 05:24AM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 07, 2012 06:52AM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 07, 2012 08:28AM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 08, 2012 07:23PM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 08, 2012 08:22PM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 08, 2012 09:56PM |
Gulf
The belt is centered above the x axis rod instead of levered off the back like most of the other designs.
Re: Who Has Built an Ecksbot? It looks CLEAN October 09, 2012 06:09AM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 11, 2012 03:32PM |
Crispy1
Besides the printed bed plate (which I experimented with and abandoned as unworkable with a HPB ),
brnrd
I think that one of the weaknesses of the Prusa i2 which still remains in the Ecksbot is having the z motors on the top instead of on the bottom. This makes the z threaded rods susceptible to downward movement if the coupling to the motor becomes loose.
Wired1
On the scond machine I built I bought some M8 stainless threaded rod which is machined to a higher standard than el cheapo zinc plated rod and it is perfectly straight to the naked eye.
ttsalo
Sadly it doesn't fix the most serious flaw, which is that the frame is stiff exactly in the direction it doesn't need to be (Y) and flexible in the direction it needs to be stiff (X)...
Re: Who Has Built an Ecksbot? It looks CLEAN October 11, 2012 11:55PM |
COOL
Re: Who Has Built an Ecksbot? It looks CLEAN October 12, 2012 07:21AM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 16, 2012 05:11PM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 21, 2012 01:36PM |
Re: Who Has Built an Ecksbot? It looks CLEAN October 27, 2012 07:36PM |
Re: Who Has Built an Ecksbot? It looks CLEAN November 12, 2012 02:20PM |
