Printer Quality
October 05, 2012 05:00PM
Hi-
I built a Prusa Mendel in the spring of this year.
I have an engineering class coming up in a few weeks and would like to have my printer printing well so I can use it for this class.
What are all the improvements one can:
a. Do fairly cheap as I am a student with a small budget
b. Require actual investment
Im all in for mcgyver solutions as long as they work, I just want to be printing at the very best quality and accuracy possible.
-Nick
Re: Printer Quality
October 05, 2012 05:04PM
Add diagonal braces to stiffen the frame. There are a few printable version available as well as the mcGyver method of using what ever you have to triangulate the frame in the direction it needs strength.
Re: Printer Quality
October 05, 2012 07:47PM
Where would braces go on the frame without obstructing the print?
-Nick
Re: Printer Quality
October 05, 2012 09:06PM
Re: Printer Quality
October 06, 2012 11:16AM
That is why the circuit board was mounted on a board on the top in the original Sells Mendel.
To provide lateral support at the same time as holding the circuit boards.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
Re: Printer Quality
October 06, 2012 05:48PM
What else can I do besides adding braces?
-Nick
Re: Printer Quality
October 06, 2012 06:00PM
It would depend on what you already have on your printer.
Herringbone gears for the extruder is nice.
Switching to T2.5 belts is a good upgrade from T5.
Metal/machined pulleys can be an important upgrade depending on how good your printed pulleys are.
Some people like z screw constraints, I have better experience with a floating x gantry, and I'm switching to M5 z leadscrews to eliminate wobble.
-Nudel
Blog with RepRap Comic
Re: Printer Quality
October 07, 2012 01:20PM
I actually need help fixing my Z wobble. Its pretty for the bottom 1~2cm of a print but then gets progressively worse. Ive tried Z constraints, but there was little change if any so im not currently using them. What can I do?
I currently have T5 belts on, how much of a difference is made by switching to T2.5 or how are GT2s?
Also the PLA bushings I received are so-so. Ive thought about replacing both the Y and Z axis bushings with linear bearings. Would this make much difference/where can one get them?
-Nick
Re: Printer Quality
October 08, 2012 08:56PM
Beuler, Beuler, Beuler...
Re: Printer Quality
October 15, 2012 10:25PM
Waiting to make an order from ultimachine to get these... so can someone tell me if they're worth it?
-Nick
Re: Printer Quality
October 17, 2012 12:27AM
How parallel are your smooth z-rods?
- akhlut
Just remember - Iterate, Iterate, Iterate!
[myhomelessmind.blogspot.com]
