heated bed problems on RAMPS 1.4
Posted by Arkady
November 04, 2012 09:27AM
Hey
I need help figuring out what my problem is.
heated bed wont heat up. everything else works fine. I checked the drain to source polarity on the mosfet and I read 3-4 ohm one way and inf the other way...
to Kliment on IRC, I attached a photo of my wiring
open | download - photo-1.JPG (54.7 KB)
Re: heated bed problems on RAMPS 1.4
November 05, 2012 07:55PM
I have the same problem and I'm not sure why it's not heating up- anyone with any advice would be greatly appreciated
November 05, 2012 08:07PM
Did you measure the voltage across the D8 terminals? How about across the heated bed terminals?
November 06, 2012 03:10AM
Are you both using marlin? if yes then it's your firmware, guarenfuckingteed. I had the exact same problem. When i get off work i will send you my configuration.h try and upload that instead of what you have now and see if you can't make the led's light up and the heated bed start heating
If you answered no to the first question, disreguard anything and everything i wrote.
A word you have used in your post has been banned from use. Please use a different word or contact the forum administrators.
