Turning off Heated print Bed
Posted by Etherflash
November 08, 2012 07:49AM
I got a problem where I got no clue what category it really fits. I can't turn off my heated bed via Gcode.
these are my last lines in a gcode file:
M104 S0 ;tip off works
G140 S0 ;no effekt
M84 ;Motors off
M190 S0 ;no effekt
now its starting to get weird I can turn the heated bed on with M140 S60
I can turn it off by clicking the off button in pronterface.
Yes the lines written abve are in my gcode I am pronting.
I'm using Sprinter
Re: Turning off Heated print Bed
November 08, 2012 11:05AM
"G140 S0 " did u mean M140 S0?
November 08, 2012 04:22PM
Hello. Logrod is right.
This are my last lines of code
G1 X12.0 F4000 ; home (almost) x - stops extruder crashing into frame if at very top of Z height
G1 Y170 F4000 ; move the print to the front.
M104 S0 ; make sure the extuder is turned off.
M140 S0 ; make sure the bed is turned off.
M84 ; shut down motors.
Edited 1 time(s). Last edit at 11/08/2012 04:22PM by epareja.
Ernesto Pareja
dcctrains.netne.net
December 09, 2016 07:29AM
Old Topic but usefull, so thank You epareja for the "M140" tricksmiling smiley
December 09, 2016 12:27PM
It's common to use M0 at the end of the slicer end job gcode. In most firmwares this turns off all heaters and motors.
