Copied from my site here for anyone who may need it:
Or this should be called… “How to convert proprietary 3D cad data into undamanged STL files without paying through the nose for expensive software.”
- Step one: Goto SDPSI (as an example) and click on a L timing pulley.
- Click on STC parts link and “download 3D models”.
- On new tab, select file formal “step, .stp”
- Let the internal website software convert the file for you (takes 30 seconds) and click download
- Open the downloaded zip file containing a stp file, such as “a_6a_4-10df05016.stp”
- Open freecad and open the step file
- On the lefthand side, click the part name under “unnamed”
- Under the help menu there is a submenu selection tool. Select “Mesh Design” and the top menu will change to include “Meshes.”
- Select mesh > create mesh from geometry, and leave the value at 0.1 on the next screen. Hit enter.
- Now on the left hand side, click “mesh”
- On the meshes menu, select export mesh. Select “Binary STL.”
- You can now process this with Slicer, Tinkercad, Sketchup (with import library included on this site).
- Print free parts!!
Unfortunately, with my silly 1 mm nozzle, I could only get the XL belt around the pulley about 7 teeth before it mis aligns. A .35mm or .5mm nozzle could surely do this.
More at
armanicreations.com]
open |
download -
(543.7 KB)
