Openscad - curved cylinders March 20, 2013 03:39PM |
Re: Openscad - curved cylinders March 20, 2013 04:33PM |
Re: Openscad - curved cylinders March 20, 2013 05:04PM |
Re: Openscad - curved cylinders March 20, 2013 05:31PM |
union(){
difference(){
rotate_extrude(120) translate ([50,0,0]) circle(10);
difference(){
cube([120,120,40], center = true);
translate([30,30,0]) cube([60,60,40], center = true);
rotate_extrude(120) translate ([50,0,0]) circle(8);
difference(){
difference(){
translate([50,0,0]) rotate([90,0,0]) cylinder(r=10,h=20);
translate([50,0,0]) rotate([90,0,0]) cylinder(r=8,h=22);
difference(){
translate([0,50,0]) rotate([0,270,0]) cylinder(r=10,h=20);
translate([0,50,0]) rotate([0,270,0]) cylinder(r=8,h=22);
Re: Openscad - curved cylinders March 20, 2013 05:38PM |
Re: Openscad - curved cylinders March 20, 2013 06:05PM |
Re: Openscad - curved cylinders March 20, 2013 06:18PM |
Re: Openscad - curved cylinders March 20, 2013 06:19PM |
Admin Registered: 13 years ago Posts: 1,063 |
Re: Openscad - curved cylinders March 20, 2013 09:22PM |
Re: Openscad - curved cylinders March 20, 2013 09:55PM |
Re: Openscad - curved cylinders March 21, 2013 01:51AM |
Re: Openscad - curved cylinders March 21, 2013 02:42AM |
Re: Openscad - curved cylinders March 21, 2013 07:32AM |
Re: Openscad - curved cylinders March 21, 2013 03:40PM |
Re: Openscad - curved cylinders March 21, 2013 06:35PM |
Re: Openscad - curved cylinders March 22, 2013 01:41AM |
Re: Openscad - curved cylinders March 22, 2013 09:44AM |
Re: Openscad - curved cylinders March 22, 2013 04:42PM |
Re: Openscad - curved cylinders March 23, 2013 11:18AM |
module bend_cut() //Used to cut out the bend.
rotate_extrude() translate([bend_r,0])circle(r=tube_r);
translate([bend_r,0]) rotate([90,0,0]) cylinder(r=flange_r, h = bend_r);
//This one is just the other way, and then rotated around the vertical axis.
rotate([0,0,angle]) translate([bend_r,0]) rotate([-90,0,0]) cylinder(r=flange_r, h = bend_r);
bend_cut();
Re: Openscad - curved cylinders April 13, 2013 04:01PM |
Re: Openscad - curved cylinders April 13, 2013 04:22PM |
Re: Openscad - curved cylinders April 15, 2013 09:00AM |
rotate_extrude(convexity=120) {
circle(10);
Re: Openscad - curved cylinders April 17, 2013 12:06AM |
Re: Openscad - curved cylinders August 10, 2015 01:23PM |
Re: Openscad - curved cylinders August 10, 2015 02:22PM |
Admin Registered: 15 years ago Posts: 730 |
Re: Openscad - curved cylinders August 11, 2015 10:28PM |
elbow(innerRadius=8, outerRadius=11, bendRadius=33);
module elbow(innerRadius, outerRadius, bendRadius)
intersection()
rotate_extrude()
translate([bendRadius, 0, 0])
difference()
circle(outerRadius);
circle(innerRadius);
translate([0, 0, -outerRadius])
cube([bendRadius + outerRadius, bendRadius + outerRadius, outerRadius*2]);
Re: Openscad - curved cylinders August 12, 2015 06:21AM |
elbowinator(angle=135, bendRadius=33)
wall2D(thickness=3)
circle(r=8);
module wall2D(thickness)
difference()
offset(thickness)
children(0);
children(0);
module elbowinator(angle, bendRadius, clipBounds=1000, convexity=4)
intersection(convexity=convexity)
rotate_extrude(convexity=convexity)
translate([bendRadius,0,0])
children(0);
linear_extrude(height=clipBounds, slices=2, center=true)
wedge2D(angle, clipBounds);
module wedge2D(angle, r, nSides=3)
polygon(points=concat([[0,0]], [for(i=[0:nSides]) r*[cos(i/nSides*angle), sin(i/nSides*angle)]]), convexity=4);
