steps per unit??!!! SOLVED
May 02, 2013 05:38AM
My reprap prusa mendel assembly is finished, everything are working fine apart of my wades extruder!
Totally stuck on calibrating. i have standard parts : nema 17 1.8 deg, ramps 1.3 using merlin and pronterface, 2.5 belts and pulleys,
calculating x,y,z steps per unit makes no problems, but extruder is pain in a...s.
can somebody in simple language explain how to calculate extruder steps per unit (mm)?
classic wades geared extruder small gear 11t and big one 39t
trying with 1.75mm pla thru pronterface extrude 5mm and it extrudes 7 cm
googling in web found page where shown that extruder ( same one) has 700 steps per unit.
tried and still no success.
Was so happy that everything is assembled, and i will be able to do some test prints, but still no goconfused smiley
Thnx
Edited 1 time(s). Last edit at 05/04/2013 05:05AM by didzix.
Re: steps per unit??!!!
May 02, 2013 06:50AM
you need to set the diameter of feedstock in software to 1.75. my extruder flow rate in firmware is between 800-900 steps per mm
May 02, 2013 07:37AM
Assuming the extruder stepper runs at all it's simple:
1. Remove the hotend.
2. Put two markings on the filament, at a distance of 10 mm.
3. Command the extruder to forward 10 mm: G1 E10 F200
4. Measure how much filament it actually forwarded.
5. If it was more than 10 mm, raise the steps per mm. If it was less, reduce the number of steps/mm. Start with about 10% each time, or see below.
6. Repeat 2, 3 and 4 until the actual filament movement matches the command.
7. For mor precision, repeat with 100 mm commands.
To get faster results, you can calculate the new steps/mm value instead of going in 10% steps:
new value = old value * distance commanded / distance moved
May 02, 2013 08:36AM
Like Traumflug said but....
There is no need to remove the hot end - mark a point on the filament which is say, 110mm from a fixed point on your extruder, command a move of 100mm and then measure the distance between the fixed point on the extruder and the mark which you have just made. If all is fine and dandy, this distance will now be 10mm. If more you need more steps per mm and if less, fewer steps per mm in your firmware. Use the formula which Traumflug gave in order to calculate the new value.
Alan
May 02, 2013 12:46PM
I can't find any line consisting feedstock diameter
May 02, 2013 01:07PM
in slic3r it is under printer settings then filament. set diameter.
in pronterface go to settings and look for sfact setup.
in sfact change the following:
in DIMENSION set filament diameter to 1.75 or whatever your calipers measurements are.
I
May 02, 2013 01:17PM
Thnx for quick replythumbs up
Just switched on my printer, heated up hot end and tried steps described.
Motor in no more turning!!It screams and vibrates but is not turning,
Plugged different stepper, and the same
Replaced driver, same thumbs down
May 02, 2013 01:20PM
One additional question.
Where can I disable function: prevent cold extrusion.
burning every time heater is no good
May 03, 2013 06:27AM
A bit confused.
There are my settings from marlin:
#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,200*16/1.25,601.89} // default steps per unit for ultimaker
#define DEFAULT_MAX_FEEDRATE {500, 500, 5, 25} // (mm/sec)
#define DEFAULT_MAX_ACCELERATION {9000,9000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for skeinforge 40+, for older versions raise them a lot.
#define DEFAULT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for printing moves
#define DEFAULT_RETRACT_ACCELERATION 3000 // X, Y, Z and E max acceleration in mm/s^2 for r retracts
and there are previous :
#define DEFAULT_AXIS_STEPS_PER_UNIT {78.7402,78.7402,200*8/3,760*1.1} // default steps per unit for ultimaker
On Extruder value what mean last number (1.1)
I assume that 760 are steps per unit
Or i'm wrong!!??confused smiley
in printerface extruding 5 mm, actual extrude are 7,9 cm
Edited 1 time(s). Last edit at 05/03/2013 06:31AM by didzix.
May 03, 2013 06:29AM
I got my stepper working by changing e feedrate under pronterface optionsthumbs up
May 03, 2013 06:53AM
any further questions on this, can you mark this as solved in the subject line
there is a setting that will not allow extruding at a lower temp in configuration.h
line 123:
#define EXTRUDE_MINTEMP 170 // this sets lowest temp to extrude to 170
extrude 760*1.1 is 836 steps per mm
in pronterface change speed as well as length. say 60mm /m and extrude 5mm of feedstock, which is a lot more out of the hot end, as the hot end is narrower than the feedstock flowing in.
Edited 1 time(s). Last edit at 05/03/2013 06:56AM by jamesdanielv.
May 03, 2013 06:56AM
Thnx for reply,
will try it.
What about value in extruder steps per unit??
May 03, 2013 09:46AM
Can somebody help with these values?sad smiley
I was googling and googling, calculated steps per mm, still something is wrong, t feeds more than 10 times more than it should.
I'm guessing that number under steps per unit means something, what i need to change,
cant find any info!moody smiley
May 03, 2013 09:55AM
[www.reprap.org]
[richrap.blogspot.de]
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
May 03, 2013 10:14AM
change XXX.XX
#define DEFAULT_AXIS_STEPS_PER_UNIT {78.7402,78.7402,200*8/3,XXX.XX}
but also know that the feedrate is calculated on material going into extruder, not what comes out. measurements are more accurate that way.
May 04, 2013 05:04AM
Thank You guys for help,
quick overview what I done
based on formula Formula from wiki I calculated my theoretical extruder E steps per mm
Calculate E_steps = motor_steps_per_rev * driver_microstep * big_gear_teeth / small_gear_teeth / PI / hob_effective_diameter
in My case : I have a 51:11 pair on my gregstruder, so I calculate 200*16*51/11/3.14159/6 = 601.89
Entered 601.89 in marlin, compiled, uploaded to arduino
In pronterface entered 5mm to be extruded
it feeded 80 mm (measured infeed in extruder)
calculation shows :my steps (601.89) per 5 mm makes 3,009.45 steps
Calculated new value: 3,009.45 / 80 (actual filament going in extruder) = 37.6181
Entered value in Marlin, uploaded, measured again and its perfect. setting in pronterface to feed 150 mm it feeds 150 mm
Now I CAN SAY THAT MY PROBLEM IS SOLVED THANX TO YOU GUYS
smileys with beer
