Help with easy drawing
Posted by dynamitetalks
May 02, 2013 10:06AM
Hey I have a hard time figuring out how to make things in sketch up, but I just need to print an easy thing, so I would like to hear if somebody can help me, it takes like 2 min if you are good. I just need it as a stl and g-code file. I hope some you dont mind
I have attrached a picture of it. its a platform to my robot.
Best Regards.
open | download - top robot.jpg (11.1 KB)
Re: Help with easy drawing
May 02, 2013 11:05AM
Try that?
open | download - dynamitetalks .STL (7.7 KB)
May 02, 2013 01:28PM
Thank you so much it looks like what i was thinking about, I'll try and see if I can figure out how to print it. again thanks so much!! (:
May 03, 2013 12:13PM
It seems that I have a problem. when im printing the platform, the extruder starts in the center of the bed and then prints to the back of the Y axel, which make the platform only printing half.
did you make the file in the center when you drawed it or outside the center?
or can I change where the extruder will print the object so it will print a full scale platform in the center of the bed?
best regards
May 03, 2013 12:37PM
here is some of the code.
I spotted that the measures in the code doesnt look right? am i right?
rinter is not online.
Connecting...
Connecting...
ok T:21.21 B:3.00 @:0
Printer is now online.
Setting hotend temperature to 185.000000 degrees Celsius.
Setting bed temperature to 60.000000 degrees Celsius.
SENDING:M105
ok T:168.49 B:3.00 @:127
SENDING:M105
ok T:176.31 B:3.00 @:0
SENDING:M105
ok T:173.44 B:3.00 @:127
Extruding 5.000000mm of filament.
1245.63592 mm of filament used in this print
the print goes from 59.260000 mm to 140.710000 mm in X
and is 81.450000 mm wide
the print goes from 69.260000 mm to 130.730000 mm in Y
and is 61.470000 mm wide
the print goes from 0.400000 mm to 2.800000 mm in Z
and is 2.400000 mm high
Estimated duration (pessimistic): 7 layers, 00:18:37
Print Started at: 17:27:18
T:194.06 E:0 Wmoody smiley
T:194.52 E:0 Wmoody smiley
T:194.97 E:0 Wmoody smiley
T:195.40 E:0 Wmoody smiley
T:195.80 E:0 Wmoody smiley
T:196.31 E:0 Wmoody smiley
T:196.65 E:0 Wmoody smiley
T:196.85 E:0 Wmoody smiley
T:197.24 E:0 Wmoody smiley
T:197.70 E:0 Wmoody smiley
T:198.01 E:0 Wmoody smiley
T:198.15 E:0 Wmoody smiley
T:198.61 E:0 Wmoody smiley
T:199.06 E:0 Wmoody smiley
T:199.23 E:0 Wmoody smiley
T:199.52 E:0 Wmoody smiley
T:199.57 E:0 Wmoody smiley
T:199.97 E:0 Wmoody smiley
T:200.31 E:0 W:0
Paused.
Entering skeinforge settings: Slic3r/slic3r.exe --load Slic3r/config.ini --ignore-nonexistent-config
Paused.
Print Started at: 17:36:27
Paused.
SENDING:M84
SENDING:M84
SENDING:M84
the print goes from 59.260000 mm to 140.710000 mm in X ( it should be 70mm wide, right?)
the print goes from 69.260000 mm to 130.730000 mm in Y ( it should be 50 wide, right?)
the print goes from 0.400000 mm to 2.800000 mm in Z (and 3 mm high...)
May 03, 2013 12:51PM
Or could the problem be the graph picture? If somebody could take a look, I would be so thankfully!! smiling smiley
Best regards
open | download - platform view3.jpg (80.6 KB)
May 03, 2013 01:02PM
The skirt adds to the dimension of the print. It's OK.
Everything else looks fine.
Look at your settings in slic3r. Is your printer tab set up properly? Especially the size of the print bed. If the print isn't centered on the bed that is where I'd look first.
I assume your machine has been calibrated.
- akhlut
Just remember - Iterate, Iterate, Iterate!
[myhomelessmind.blogspot.com]
May 03, 2013 01:38PM
Thank you akhlut smiling smiley
as you can see is my bedsize sat up to 140 mm * 100 mm * 100 mm
and center size 70 mm * 50 mm
I cant really not figure out why it prints out to the edge of the bed and by then only print a half sized platform.. see the attached picture off my printer.
Best regards
open | download - printrbot view.jpg (247.5 KB)
May 03, 2013 01:49PM
The center of origin when I made the part is the geometric center of the part. (Best Modeling Practices)
What's your print center set to?
http://brazenartifice.files.wordpress.com/2011/12/slic3rs-filament-settings.jpg
NOTE your picture of the graph from Pronter Face.
Each little square is 10mm x 10mm. (You can tell because the part is 7 squares long and 5 square wide)
So you have placed the part outside the limits of your printer of 140mm x 100mm
Edited 3 time(s). Last edit at 05/03/2013 01:54PM by ShadowRam.
May 03, 2013 01:54PM
Thanks ShadowRam.
my settings is attached as a picture..
Best regards.
open | download - sli23.jpg (56.2 KB)
May 03, 2013 02:01PM
thanks tripple times ShadowRam
I hope it wasn't me who did it, because if so I dont know what I have done.. but what can I do to make the slicer file be in the leftcorner instead of 7 squares away from the left corner?
Best regards
May 03, 2013 02:09PM
That I'm trying to figure out myself.
I'm at work at the moment, and I don't know the answer to that. Sorry sad smiley
It has to be at the point where you put the STL file into Slic3r to make the Gcode.
May 03, 2013 02:12PM
Alright thats fair Thanks, I'll try to work on that. smiling smiley
May 03, 2013 02:16PM
I did everything from the beginning and know it prints on the bed, still not in the center but nearly! but it looks great smiling smiley
Thanks a ton for your help!! have a great weekend!
Edited 1 time(s). Last edit at 05/03/2013 03:07PM by dynamitetalks.
open | download - slic3r.jpg (59.3 KB)
