Buying through Aliexpress? May 09, 2013 04:02PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: Buying through Aliexpress? May 09, 2013 04:51PM |
Re: Buying through Aliexpress? May 09, 2013 05:33PM |
Re: Buying through Aliexpress? May 09, 2013 06:09PM |
Re: Buying through Aliexpress? May 09, 2013 06:43PM |
Re: Buying through Aliexpress? May 09, 2013 07:05PM |
Re: Buying through Aliexpress? May 09, 2013 07:14PM |
Re: Buying through Aliexpress? May 09, 2013 07:23PM |
Re: Buying through Aliexpress? May 09, 2013 09:15PM |
Re: Buying through Aliexpress? May 09, 2013 11:06PM |
Re: Buying through Aliexpress? May 10, 2013 03:17AM |
Re: Buying through Aliexpress? May 10, 2013 06:50AM |
Ohmarinus
Well, I think that through the G3D kit I'm better off, since it uses the G3D steppers, from which I have read very good and positive reviews. In the wiki it says they are the 'new generation' of stepper drivers. Let's hope it's true.
Re: Buying through Aliexpress? May 11, 2013 02:48AM |
Re: Buying through Aliexpress? August 26, 2013 07:20AM |
Re: Buying through Aliexpress? September 02, 2013 07:46PM |
Re: Buying through Aliexpress? September 24, 2013 04:10PM |
Re: Buying through Aliexpress? January 07, 2014 08:23AM |
Re: Buying through Aliexpress? January 07, 2014 09:29AM |
Re: Buying through Aliexpress? January 07, 2014 02:31PM |
Re: Buying through Aliexpress? January 08, 2014 05:21PM |
Re: Buying through Aliexpress? January 08, 2014 06:15PM |
Re: Buying through Aliexpress? January 14, 2014 01:23PM |
Re: Buying through Aliexpress? January 15, 2014 01:28PM |
tjb1
If you order, do not click "I've received item......" because once you click that you can no longer open a claim or anything from what I have found. I have had a claim open on another order for 3 weeks now and I am still waiting, Aliexpress is supposedly waiting on the shipper to provide information and gave them 3 days to do so...well its been 7 now and I haven't heard anything else. I'd stick with eBay for anything higher priced.
Re: Buying through Aliexpress? January 17, 2014 05:00AM |
Re: Buying through Aliexpress? January 17, 2014 05:46AM |
ecoreprap
AliExpress is not so friendly,one reason is that they charge 5% for the seller the other is that the logistic is very slow.
Re: Buying through Aliexpress? January 18, 2014 10:56AM |
Re: Buying through Aliexpress? January 18, 2014 11:02AM |
victorjung
There is no problem i mean i bought many through them, you are dealing with the same kind of pro and cons you have when buying to chines ebay dealers.
Re: Buying through Aliexpress? March 24, 2014 03:22AM |
tjb1
tjb1
Just an update to this...still no action from the case. Will not be buying anything else from aliexpress or alibaba.
Re: Buying through Aliexpress? March 24, 2014 11:12AM |
Re: Buying through Aliexpress? March 27, 2014 08:41AM |
That's kind of like asking which company is the most reliable, tested, and/or trusted on ebay. Or Amazon marketplace. Or any other similar marketplace with multiple vendors under one site. There is one vendor that meets that criteria and even if there was one for motors for instance, they may not have your electronics. Or linear rod. Or some other component. Or the best vendor may have an issue with a particular order but overall they are a good vendor. That's what their ratings are, and just like any other site, you have to take their rating with a grain of salt and use your best judgement. And even then, you can still get burned.Quote
opeyemi
which company is the most reliable, or tested and trusted at aliexpress?
