IR heat lamp heated ABS build: May 17, 2013 04:18PM |
Re: IR heat lamp heated ABS build: May 17, 2013 11:12PM |
Re: IR heat lamp heated ABS build: May 17, 2013 11:27PM |
Re: IR heat lamp heated ABS build: May 18, 2013 02:07AM |
Re: IR heat lamp heated ABS build: May 18, 2013 10:20AM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: IR heat lamp heated ABS build: May 18, 2013 12:59PM |
Re: IR heat lamp heated ABS build: May 19, 2013 03:45AM |
Re: IR heat lamp heated ABS build: December 21, 2013 06:33AM |
Re: IR heat lamp heated ABS build: December 21, 2013 07:58AM |
Re: IR heat lamp heated ABS build: December 21, 2013 11:09AM |
Re: IR heat lamp heated ABS build: December 22, 2013 07:06PM |
Re: IR heat lamp heated ABS build: December 22, 2013 07:56PM |
Re: IR heat lamp heated ABS build: December 22, 2013 09:19PM |
Re: IR heat lamp heated ABS build: January 04, 2014 04:26PM |
Re: IR heat lamp heated ABS build: January 04, 2014 05:01PM |
uGen
A little bit disappointing to read that the PP didn't really heat up as I have hoped to be able to print exactly that. Can you explain your setup a little bit more? Also, colored filament might react differently to IR, right?
Re: IR heat lamp heated ABS build: January 05, 2014 09:33AM |
Re: IR heat lamp heated ABS build: January 05, 2014 11:56AM |
jamesdanielv
i would think it better that someone could slightly see the ir light. that way it would be known it was on, and some safety precaution would be taken to protect the cornea of the eyes.
if the ir was not heating the surroundings aluminum would work ok, but it likely will get quite hot. perhaps aluminum and then insulation
Re: IR heat lamp heated ABS build: January 05, 2014 12:26PM |
Re: IR heat lamp heated ABS build: April 10, 2017 07:39PM |
Re: IR heat lamp heated ABS build: April 11, 2017 02:15AM |
Re: IR heat lamp heated ABS build: April 11, 2017 07:05AM |
Re: IR heat lamp heated ABS build: April 11, 2017 11:31AM |
