reprappro tricolor mendel problems.
Posted by mekastudios
May 22, 2013 05:35AM
Hey guys.
Need some help. I have assembled and am trying to calibrate my tricolor mendel with one extruder. I am having a few problems.
I have attached a picture of what the print is like now.
open | download - Screen Shot 2013-05-22 at 5.32.00 PM.png (401.9 KB)
Re: reprappro tricolor mendel problems.
May 22, 2013 06:31AM
so you mean the X axis shifted to the left in 2nd layer?
May 22, 2013 06:34AM
Hi
It looks like your motors are skipping (or the pulley is jumping the belt - the belt needs to have some tension in it) in the X axis. Also, the first layer is printing a bit high, by the look of the infill. I see you have mounted the other hot ends - are you sure they are not too low and catching on the print?
Is there a reason that you have mounted the nozzles with cable ties?! That isn't in the instructions!
Edited 1 time(s). Last edit at 05/22/2013 06:35AM by droftarts.
May 26, 2013 02:06AM
Hi. Solved the problem by tensioning the belts. Thanks for the advice.
The cable ties are actually just to keep the extruders tight around the carriage. they seemed a lil bit lose and were sagging. The extruders are still mounted with screws as per the instructions.
Yeah I adjusted the Z-endstop a bit and have managed to get a few prints now. There was a problem with a wobble towards the left side. I'm gonna try to tension the x-axis a bit more and hopefully that solves it.
open | download - Screen Shot 2013-05-26 at 2.01.44 PM.png (581 KB)
