speed of sending data to the board
Posted by moltean
June 17, 2013 04:09PM
I'm testing a board from a PC program created by me.
The problem is that I don't know how many lines of G code can be sent to the board ...
should I wait for a few milliseconds before sending a new G code command ?
or is there a command that tells me that the board has executed all the commands in its cache ?
thanks,
mihai
Re: speed of sending data to the board
June 17, 2013 08:20PM
typically it is 4 to 16 commands and a maximum of 63 char per line
You can wait for the checksum return, or the ok response.
Edited 1 time(s). Last edit at 06/17/2013 08:32PM by jamesdanielv.
June 18, 2013 08:07AM
After accepting a line of G-code, firmwares send back an "ok". This is sort of a flow control. Marlin ans Sprinter limit G-code lines to 63 characters.
Teacup offers XON/XOFF flow control in addition to the "ok"-type. The advantage of XON/XOFF is, it's handled at the driver layer, no need for the application to take care. The drawback is, pausing a print is almost imossible, because drivers have rarther large buffers (typically 16k or several hundred lines of G-code).
For an even more advanced concept, see [reprap.org] AFAIK, no implementation, so far.
