Microstepping jumper settings June 22, 2013 02:22PM |
Re: Microstepping jumper settings June 22, 2013 03:49PM |
Re: Microstepping jumper settings June 22, 2013 04:39PM |
Re: Microstepping jumper settings June 22, 2013 07:30PM |
Re: Microstepping jumper settings June 23, 2013 07:45AM |
Generation 7 Electronics | Teacup Firmware | RepRap DIY |
Re: Microstepping jumper settings June 23, 2013 02:13PM |
Re: Microstepping jumper settings June 23, 2013 02:33PM |
Solder MS1, MS2 and MS3 jumper headers. I find that it is easier to solder the 2-pin header if the jumper shunt is installed. Ensure they're completely seated and straight. Leaving the jumper shunt in place will pull the MS pins high, i.e. set the Pololu controller to sixteenth step resolution. This turned out to be the appropriate setting for my out-of-the-box firmware. If your motors move erratically, check these.
Re: Microstepping jumper settings June 23, 2013 06:09PM |
Re: Microstepping jumper settings June 27, 2013 10:42AM |
Re: Microstepping jumper settings June 27, 2013 11:46AM |
Re: Microstepping jumper settings June 27, 2013 05:18PM |
Re: Microstepping jumper settings June 27, 2013 06:11PM |
Re: Microstepping jumper settings June 27, 2013 06:48PM |
Re: Microstepping jumper settings June 27, 2013 08:14PM |
Re: Microstepping jumper settings June 28, 2013 06:18AM |
Re: Microstepping jumper settings June 28, 2013 08:18AM |
Re: Microstepping jumper settings June 28, 2013 01:59PM |
Re: Microstepping jumper settings June 28, 2013 11:59PM |
Re: Microstepping jumper settings July 02, 2013 06:14PM |
Re: Microstepping jumper settings July 02, 2013 08:48PM |
Re: Microstepping jumper settings July 03, 2013 05:09AM |
Re: Microstepping jumper settings July 03, 2013 06:22AM |
Re: Microstepping jumper settings July 03, 2013 02:03PM |
Re: Microstepping jumper settings July 03, 2013 05:59PM |
Re: Microstepping jumper settings July 04, 2013 01:21PM |
