I just got started with a Makerfarm 6" Prusa i3. I've gone through calibration but did some checking on the heated bed and found significant differences between the thermistor readings (on the bottom of the heated bed PC
and the temperature on top of the glass.
When I set 60C for printing PLA, my actual temperature on top of the glass ends up significantly lower. To get an actual temperature between 58C and 70C I have to set the bed temperature to around 90C in pronterface. I get around 12-15C variation between the middle of the heated bed and the edge where my measuring thermocouple is clamped.
I've checked my readings with a thermocouple on a digital multimeter as well as with an IR thermometer.
I'm just wondering if others have found similar results and is this just another calibration step?
