Reference des 4 angles de la table possible?
Posted by Rico13
September 08, 2013 06:52AM
Bonjour,
es ce qu'il est possible point de vue soft:
j'aimerai mettre un switch juste en dessous la tete de chauffe et bien dans sont axe, en parallele du switch Z de fin de course pour:
- prendre une references des 4 angles de ma table de chauffe pour savoir le delta de hauteur entre les 4 angles et voir de le prendre en compte dans le profile de mon imprimante afin d'etre sur que le deplacement de la tete de chauffe soit toujour parallele a ma table.
Merci
Edited 1 time(s). Last edit at 09/08/2013 06:54AM by Rico13.
Re: Reference des 4 angles de la table possible?
September 08, 2013 07:11AM
Hello,
is it possibl?
I would like to put a switch removable just below the head and axis is in line, in electrical parallel to the switch Z limit for:
- to make reference for the 4 corners of my table heaters to learn delta height between the four corners and see to take into account the profile of my printer to be sure that the displacement of the head of heater is Still parallel to my table.
thank you
September 08, 2013 03:13PM
If you are talking about probing the height of the bed to compensate for how flat it is, yes it is possible. It's even been done before. A bit of searching should find you what you need. "RepRap bed probe" for example.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
