How do you fix a revolve joint?
Posted by demetris
September 19, 2013 11:47AM
Hey!
Sorry is this is a silly question, but I have these two parts (from a gripper I am designing) that need to revolve against each other (simpler than it sounds, check the image). I used a simple screw and nut and (as expected) it becomes loose after few movements. Essentially the parts unscrew the nut. What is the easiest way to overcome? The only thing I am aware of are the nyloc nut but I don't think it is the correct solution.
Thanks!
open | download - 20130919_182920.jpg (46.2 KB)
Re: How do you fix a revolve joint?
September 19, 2013 11:59AM
You can use a nylstop nut or loctite, or try two nuts.
September 19, 2013 12:15PM
Tried the two nuts but again they unscrew after the second or third movement...
Tighten the nuts against eachother.
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing.
Anyone can edit the wiki!
September 19, 2013 03:36PM
Oh I see! IT WORKS!!!
Thanks guys! Seriously thanks a lot!
Demetris
September 19, 2013 08:08PM
if you want it to work reliably over a long time and thru temp cycles you will want to tap the nut on one of its 6 sides and place a grub screw in an tighten it down. It will lock the nut in place. Even better drill thru the nut and bolt, and place a pin.
if you need reliability, or it hinges a device that prevents something dropping or moving, these next steps are preferred.
