So I was ordering some parts online for my Prusa I2 and I ended up ordering so stepper motor cable to redo the wiring. here are some bad connections in the wiring from the previous owner. Well I missed the fact that is is 18 awg and when I solder the molex pins on it won't fit all the way down into the standard Molex connectors for the Ramps board. This is my first project using these connectors, and I was wondering if they are screw type connectors (similar to the power input) that will slip down on to the pin connectors. The only ones I've found seem much to big to fit the ramps boards. Thanks.
-Clark
