I am trying to set up a dual bowden extruder using Slic3r as the slicing software, but I am having some issues with ooze on the non-active extruder. Over time, the inactive extruder begins to ooze and when it finally travels over the part, it will wipe itself on the part, leaving messy trails.
Slic3r has a setting for retraction when the extruder is disabled, and I have been playing with this and it doesnt seem to have much effect. I have tried 5mm, 10mm, and now 13mm and I dont see any meaningful difference in the results. extruder alignment looks good, but I cant seem to get rid of the ooze.
I am using 2 E3D metal hot ends, which seem to ooze a lot less than many of the hot ends I have used before. I am currently extruding ABS at 240C in both extruders, but the problem persists even when I try dropping the temp all teh way down to 225.
Anyone have any ideas what to try next? I see lots of pictures of nice looking dual color prints and I cant believe that they are all cleanup up as much as mine requires.
