Calibration is driving me absolutely nuts, simple question. (Pics)
October 08, 2013 07:21PM
Hey guys. In having an issue I can't fix. The tops of my surfaces are just not filling in solid! The bottoms are solid due to 300% width, but when I put the top to 300% it still comes out as shown in the object on the right. Here's what I'm printing at
Nozzle: .4mm
PLA 190 degrees
.15mm height
My E steps per mm was 700 in Sprinter but not it's al the way up to 850 and I'm STILL getting those results.
Any ideas? Thanks everyone.
open | download - image.jpg (218.1 KB)
Re: Calibration is driving me absolutely nuts, simple question. (Pics)
October 09, 2013 03:07AM
Are you sure the amount of extruded material is correct? It seems that there is simply material missing.
October 09, 2013 03:56AM
try slowing the print down. people think 3d printing is really fast. it can be but not on solid fills. slow the entire print down by 1/4 and see if your results improve. tweak settings from there!
October 09, 2013 08:55AM
What percent fill? What height is the object? If you use .2mm layers does it work better?
October 09, 2013 10:46AM
Are you sure your nozzle size is set correctly in your slicer? Double check it.
